buying a rb25: compression test results
Neejay
1-1202-1233-1194-1195-1216-119
He said it was on a "****ty autozone" tester.
This is the one I was planning on buying, but I requested a compression test first. Thoughts?
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
well the results are pretty even....from the looks of it the cylinders are prob dry with no oil in them....put four or five drops in each cylinder and the compression will jump up to where it should be.
Neejay
Yeah, I replied back to him asking if the engine was warm + WOT cranks...awaiting a reply now.
Neejay
Well, the guy said the engine "had cooled a little bit" but the test was done at WOT...
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The numbers are not "high" or even close to FSM spec, but they are even and that is what matters most in a compression test. Highly unlikely that all of the rings are evenly fried unless the engine has like 200,000 miles on it.
Neejay
Darius wrote:The numbers are not "high" or even close to FSM spec, but they are even and that is what matters most in a compression test. Highly unlikely that all of the rings are evenly fried unless the engine has like 200,000 miles on it.
So should I go for it?
Sil240
Car: Nissan S13 "The One Cam Wonder"
WOT Cranks???While doing a compression test????This guy doesn't know what he's doing or he's trying to bs you.
You don't do a compression test @ WOT.You put the tester in the hole and crank with the key. The Throttle has no play in a compression test.
I personally would stay away from it.Your in ATL go find one of the importers there.I think Jarco is there and maybe JHot not sure though.Check with our sponsors maybe there in your area. Rent a uhaul or buy a buddy with a truck lunch on a 6 pack and go get that beyotch.
Also if a deal is too good to be true... I just might be.
Neejay
Sil240 wrote:WOT Cranks???While doing a compression test????This guy doesn't know what he's doing or he's trying to bs you.
huh? You're supposed to have the throttle completely open to get the highest possible compression.
Darius
Shocker
Car: 89 240sxHB rb26/30
Neejay wrote:huh? You're supposed to have the throttle completely open to get the highest possible compression.
yup yup.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Shocker wrote:
yup yup.
+3
BoostFab
Car: S13cp, S13fb, S14z
someone here is a post whore and no clue what he's taking about !!!!
Joe
also a little known fact, you should remove ALL the spark plugs too. if you dont, you could get a false reading because of between cylinder headgasket failures.
Shocker
Kamin wrote:also a little known fact, you should remove ALL the spark plugs too. if you dont, you could get a false reading because of between cylinder headgasket failures.
Also you want the motor turning over as FAST as possible, so less load = quicker turning.
Joe
also less painful to your starter and battery lol
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
OMG! Never ever give advice again....
lilskyline240
Car: 90 240sx w/ rb30det
when i compression test i remove all my plugs. Plug a batt charger onto the battery to keep the RPMs as high as possible while cranking, hold gas pedal to the floor. then crank till the needle stops moving. should give u the best results
BoostFab
lilskyline240 wrote:when i compression test i remove all my plugs. Plug a batt charger onto the battery to keep the RPMs as high as possible while cranking, hold gas pedal to the floor. then crank till the needle stops moving. should give u the best results
that's pretty much it, it's not rocket science, guys!rotate the engine 4-5 times should do it.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Yea I only crank it over about 5-7 times.
