oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Fri Sep 26, 2008 4:41 am
Wow.....lots to say and for you to consider. It really depends on your point of view. Read old threads regarding maintenance on this site and you will get a wide variety of opinions. Here's mine:
If it's been properly maintained 85,000 is nothing. Id' drive it to Montenegra and back. "Properly maintained" however is a highly subjective statement.The dealer will be able to pull the VIN and give you a printout of all the maintenance work done on the car since it's birth. That will be all the work done by Infiniti shops, not any other garage. So, if the car was dealer maintained then you will have a pretty good baseline of the car's history. If it wasn't, then the whole exercise could be a waste of time.
At 85K, your car is just rolling into an area of potential intensive care. How intensive is dependent largely on how it's been driven and maintained over the years.
At the least, it should have had regimented and consistent oil changes. IF you care to research this site you will see that clean fresh oil is a major component of maximizing the engines life and reliability. However, I stole a Q last year without such a record and my engine runs like a string trimmer on NOX. My car was dealer maintained for only it's first few years and at whoopeee lube after that. Now, it may blow up tomorrow, but I have put 20K on it in the last 9 months and I'm not worried, The engines in these mothers are well engineered and robust. There are plenty of guys here who have 250K on their engines. Of course, I would have rather bought a car from someone who was super anal with the lube, but I was not so fortunate....or at least have no record.
In general, fluid changes are considered the Holy Grail of maint on this site. ALL fluids. Trans, Diff, Brake, PS, Blinker etc More often is mo' good.
Ditto on all filters. Intake, fuel, cabin air, etc etc.
At 85k the suspension is probably ready for some rehab, and this will cost you plenty. Shocks can only be purchased from two sources, the dealer ($$$), and aftermarket sources in Japan ($$$$). Stay away from a touring model unless you're loaded. It's too heavy a car to justify that kind of gizmometry in my opinion. At 4000 pounds, handling is not it's forte, but on the interstate it's a wonderful beast.
I spend some time in BC and I have never seen a Q there. Are you going to do your own wrenching? If so, take the plunge. If not, I'd recommend an Acura or similar. Changing the plugs takes about 3 hours....ditto the belts. At 85 bucks per, even routine maint on these mothers will kill you. And God forbid it actually breaks (can you say transmission four thousand???? whaaaatheffffff??).
I'll quit and let others opine. I am one of the sites premier slackers because I am less than anal with my ride. I do a fair amount, but within reason considering I only paid 4500 bucks for it, and it's now 9 years old. There's only so much rehab that I can justify on this thing. But nothing is busted and it's clean. But I do have limits. I am not going to tear into it just to find things to fix (beyond reason). ie I have not polished my caliper pistons, armoralled my seat springs, etc. Perhaps if I bought it new...but not at 120K
These are really fantastic cars. They are well engineered, well built and a freakin' joy to haul a$$ in. Hell, they're even nice doing the boring posted speed limit. I stumbled across this site AFTER I bought mine and nearly shat myself with fear while reading some of the doom and gloom posted herein. But I put on my depends and jumped in with zeal to bring it up to speed. I have now have reached a level of detente with it. I treat it good, but not too good. It's my high maintenance beeotch, looks and feels like a million bucks. When it gives my crap, I drive my truck.
Skin your knuckles!
Modified by oldmako at 5:01 PM 9/26/2008
