Buying a 98 Qx4
ilyb
Hi, I am new to the forum and hopefully I'll be one of the proud owners for the QX4 soon.
I have checked one out today with about 143k miles, everything seems ok, minor issues such as the antenna doesn't go down(probably a dead motor?), cassette doesn't work, and the A/C probably needs a recharge.
The only thing that got my attention was that the driver side of the qx4 is sitting higher than the right side. I've looked up the web and got this:http://consumerguideauto.howst...2.htm
Air springs: The vehicle may sit crooked because the left front spring compresses more than the right requiring a countermeasure spring. (1997-98)
I checked the qx4 and only saw the coil springs? If there is air springs, how should i fix the problem?
If there are just coil springs, do I simply replace the springs or/and shocks to fix this problem?
How costly to actually fix it? costly enough to walk away from this QX4? The owner said the shocks/springs have not been replaced.
Thanks guys/girls in advance!!
korbeano89
Car: 1997 Infiniti QX4
the questin is how much are you paying for it because theres alot of them out there. you could find a better one, and qx4s, you cant go wrong. they are great cars and you wont be disappointed. i will get another one , just thought id put that out there.
ilyb
I'd say it's about 800 to 1000 cheaper than the average ones. So I thought if this problem can be fixed within 500 to 800 it's still a deal considering the rest of the qx4 is well maintained.
Tires need to be replaced, but I am planning to buy new tires for the winter anyway.
ilyb
I've finally bought the qx4, it's been great so far for 2 days~~! however, I do feel very bouncy when hitting bumps or making turns especially on the passenger side. Pretty certain I need to replace the shocks.
Any experts out there can confirm if air springs exist in the 98 model? If not, I can pretty much change the springs and shocks to solve my problem (driver side is higher than the passenger side) right?
Thanks!
KyooX4
Car: 2001 Infiniti QX4 4wd
No there aren't air springs. In the front there are coils and struts, and in the back there are coils and shocks.
By the way, congrats on the purchase!
fueler
Car: 2 Nissan's
2 BMW's
i wouldn't worry about the drivers side being higher - it likely levels out when you sit in it.
congrats on the purchase, these are more reliable and more comfortable than a 4runner, at a fraction of the cost because people don't know about them!!!
