AZ-ZBum wrote:So the differences between the NA and TT Z32s are:- twin turbos (and minor internal stuff)- adjustable suspension- wider rear wheels- HICAS
What else? What else could you get on the TT that wasn't available on the NA? I'm actually trying to get information. You guys are getting all defensive.
There is more to it, but here's some of the motor stuff that I had saved on my computer.
1. The blocks are similar. They both have oil squirters that direct oil towards the underside of the piston, but they point at different angles. The oil squirters on the TT direct oil straight into a off center hole on the underside of the TT piston, which leads to a hollow area inside the top of the TT piston. The NA ones just direct the oil towards the middle of the underside of the piston which has no passages inside. They blocks have all of the same oil passages. Two passages are plugged with a bolt on the NA block (one on each outside face that feed the turbos on a TT). The TT has two oil passages plugged inside where the oil filter bracket mounts, the NA has two small check valves in this location. They are plugged in the TT providing more pressure so that the oil will go through the lines to the oil cooler, which returns back to the oil pan. There are check valves on the inside of the TT oil filter bracket where the oil filter screws on, but none on the NA The purpose of these check valves is if the oil filter somehow becomes clogged or collapses that oil will still circulate.
2. Piston rings, and Crankshaft (main) bearings are the same. The rod bearings are the same size but the TT ones are a different alloy (kelmet).
3. Of course the pistons are different because of lower compression ratio in the TT, 8.5:1 in respect to 10.5:1 on the NA. The internal structure of the pistons is also different, the TT ones have a hollow ring inside the top that fills with oil for better cooling and a thicker dome towards the center.
4. Oil pumps are different. They mount the same and are the same internally except for the spring for the pressure valve in the TT one is tighter, so it produces more needed pressure to circulate oil to the turbos and cooler.
5. Oil filter bracket on a TT is different (longer) because it has an outlet that accommodates the hose going to the oil cooler. There is a spring loaded valve in the bracket that will not let the oil circulate to the cooler unless there is sufficient pressure. The NA does not have an oil cooler.
6. Intake cams are different. All the exhaust cams are the same. The 94-95 cams were different than the 90-93 but just like the earlier ones they are all the same except for the intake cams on the auto TT. The 96 cams were ALL the same.
7. The valves are all the same size. But the exhaust valves on a TT are made from a stronger alloy (iconel)
8. The bare heads are different.
9. The spark plugs are different, they run different lengths.
10. The oil pan is different because the TT one has 2 tubes protruding on the sides where the oil return hoses for the turbos mount and another one for the hose returning from the oil cooler.
11. The turbo engine obviously has a few different accessories and systems to accommodate the turbos. The exhaust manifolds on the TT are much shorter than the NA ones, which go all the way down and tie into the exhaust section including the catalytic converters. The turbos are oil lubricated and water cooled. So there are oil and water, supply and return lines everywhere on a TT motor.
12. The throttle bodies are the same size but the passenger side one is different on a TT simply because one of the water lines attached to the bottom of it has a junction in it to feed water to one turbo.
13. The upper and lower intake manifolds are the same TT and NA 90-92. The newer ones are different from the earlier ones. They made the change to the new style injectors, lower plenum, and the intake port on the heads in 93 for the NA but not till 95 on the TT. So lower plenum and heads would be different on 93-94 NA and TT's. The upper plenums changed just a small bit in 94 when the angle that the flange of one of the EGR tubes bolts on to the plenum rotated about 30 degrees. Just enough stuff to make interchanges a pain.
14. Head gaskets are different.
Modified by nsrZ32 at 3:54 PM 4/9/2006
