countrygirl403 »
https://forums.nicoclub.com/countrygirl403-u147194.html
Tue Nov 09, 2010 1:38 pm
Hey, just want to ask you if you have heard of the problems with the '05 's and the IPDM? I own 2 of them and have replaced the IPDM on both. Did a lot of reading last year when mine quit running. Would not even show codes to identify problem. After much reading on various forums, replaced the IPDM. Now a year later, I am back in the same boat with my car sitting in shop with rough running issues. I can't believe that this has happened to me again! Thought that once I made the repair I would be good to go. My daughter's had not completely quit, but just failed to start on several occasions. I replaced hers when she left for college so would not be left on roadside. Now 2 months later, hers is failing to start again. Just be safe and try to do a little research. Maybe I just have the worst luck ever! There was a lot of posts last year on these problems. Look back to the fall and see if you can find them. I am about to try and get back and recheck which sites I was on. I did find my post on Edmunds.com, but never had a reply from there. Lots of dialog on other sites, when I get home I will find for sure which sites I was on. I think this NICO was one of them. There were posts from owners of the Titan pickups also. Good luck.
