MisterH wrote:$2700 seems awfully high for one that old. Depends on market where you reside I guess. Strongly urge you to do a vehicle history report via AutoCheck or CarFax.. You might find it's had ten owners and several major accidents. RE: timing belt, but it almost doesn't matter what was or wasn't done before because it's nearly due for timing belt change #2.
thanks. I think im going to pass on this one. I found an 01 qx4 for around the same price. Its in good condition.
Anything I need to consider on the qx4 compared to the pathfinder? As i understand the qx4 is a 3.5 and therefore a timing chain. The car has had regular maintenance so I'm not too worried but if there's anything I should know that's specific to the qx4 (or pathfinder.. but they're the same car except aesthetics right?) then I'll need to consider it.
