evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Mar 23, 2017 9:08 am
Welcome to NICO!
Often people advertise low original miles on cars where the odometer has rolled, maybe eve more than once, and the present owner might not know any better. Look at the wear items where you touch the car, the steering wheel, shift knob and pedal pads. at 76k original miles they should not show a lot of wear, if they are completely smooth then it's likely rolled the odometer at least once, not that the miles are a big deal just know that going in. So to answer:
1. upholstery kits are readily available, from a number of suppliers. Replacement foam is also available if you need it.
2. Plenty of aftermarket sources for carpet kits as well
3. This could be a number of things, generally rpm related issues are related to the afm and or the tps. Could also be a fuel pump getting weak or even the coil, cap or plug wires. It's likely not going to be a problem with the engine itself but could cost anywhere form nothing to several hundred dollars to fix, no way to know until you do real diagnostic's on the car.
4.Rust is like icebergs and cockroaches, what you can see is a fraction of what's really there. It's also a can of worms you might choose to leave unopened if it's minor enough.
$4500 for a decent driver quality car is cheap, but it's still a 280 and the best ones aren't worth a whole lot more, based on the questions you're asking there probably isn't a lot of room for profit. If you are a decent problem problem solver and get the running issue worked out, find a good used seat, and a cheap carpet kit you might make a few bucks, maybe.
