GuidoInc wrote:96 Q45 100K how difficult is it to remove and press in the bushings?
VimyJ wrote:I very recently replaced my entire suspension with OEM parts. After 1000 miles, the initial harshness of the ride has left. I am amazed at how well balanced the J is now. The car is entirely predictable. I have discovered that the J is now prone to oversteer. There is so much more control input from the front wheels. Throttle steering is a blast. The J sets up beautifully. This is a performance car. Perfect tourer.
Coming out of corners is a whole new experince. Haven't nailed one perfectly yet but I'll keep practicing.![]()
There is a shop in NJ run by an ex-Infiniti master technician named Keith Vanmeter. Do a search and his phone number might show-up.louiegz wrote:Non DIY Q owners like me are screwed. My dealer has been telling me about the tension rods for the longest but the job will cost close to $700.00 to change them. If I ask them to just change the bushing, they will most likely say no. I have a friend that owns a Mieneke to have the muffler change on my Honda Accord I just sold and he didn't know what tension rods were. He thought I was talking about tie rods. I worry about getting work done here because I dont think he has done a lot of work on Qs before. Not only that, He did my brakes one and they made noise. I was hoping he knew about it because when I asked him about installing the Tokico Blues ( for $300.00 labor) in my Q and I figured it would be a good idea to get the t rods done at the same time. What are the kind of questions I should ask mechanics to see if they know how to do this job? The other reason I'd like to replace only the bushings is that it should last longer that the liquid filled bushing in the OEM t rod. Also whe I get my shocks done, what other bushings should I have changed?
Jeff Williams wrote:If you want to drive to Alabama, I'll help you do it. Just wait until after Christmas.
First of all, these have sold for less than half that amount on eBay, before. Second of all, they will fit your car. But most importantly, do not put them on the car, unless you are upgrading all the other bushings at the same time, to poly, aluminum, or teflon. This part is meant for the lighter cars, and intended for those who intend to race the car on a track. The liquid filled rubber absorb a lot of the day-to-day stress of the suspension. A solid mount will stress the rest of the suspension a great deal, and will cause failures in other suspension parts.louiegz wrote:I ask about the Z t rods because I saw these on Ebay.
http://cgi.ebay.com/ebaymotors...02593
The look a lot like the Stillen ones they sell for the Q, and it looks like the bushing shold last longer because its not liquid filled.
So Heath, if doing the t rods are that easy, then maybe I should stop being such a baby and do it myself. What's the worst that can happen? How bad can I screw it up? So how do I do it?
