DUH!fiznowler wrote:LOL at the helpfulness of nico sometimes. Get all machine work done first. Buy the pistons and bearings to fit what you had it machined to. IF you buy parts first your block could be worse off than you thought and require different parts.
This might be true if you were using stock equipment, but even stock has different grades, so that makes your point moot if you can get a good measurement of the cylinders. If you can't find a company that makes exact enough pistons after you shored up the block, change companies.240freak90 wrote:your machine shop NEEDS your new pistons to be able to bore and hone your cylinder to the correct tolerances and if they say they dont then dont let them machine your block.
it doesnt matter how you make them or how good of a company they are there WILL be some differences. they cant make every single piston exactly the same. yes you can have them bore and hone first then buy pistons to fit but imo its safer to buy what size pistons you are going to use and send them to the machine shop with your block so they can bore it and finish hone it to the correct tolerancesDattebayo wrote:
