QuinGarcia wrote:I am running an autometer temp gauge. No, I didnt know there was a bleeder screw on the upper water neck. By "upper water neck you mean the aluminum outlet from the cylinder head to the upper radiator hose that is on the turbo side of the engine (as opposed to the intake manifold side). My engine is a redtop s13. The radiator hoses are getting hot, but i think only because they are attached to the hot engone, I'm not sure if they are flowing much water because my radiator is not gettting hot.
The bleeder screw is on the upper water neck. The upper water neck is on the front of your engine just under the CAS.
