float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Feb 03, 2012 8:11 pm
Up to 350HP, keeping the valves is a good idea. Is the rod still there? If so, then yes, you can swap the valves over, just make sure and loc-tite the threads with RED threadlocker. If the rod is gone, then he's probably altered the sub-manifold and you can't just swap the stuff over. You'll have to swap the entire sub-manifold over.
I've run the engine both ways, and I would keep them. Yes, the emance rom tune doesn't alter the butterfly valve function. Please see the FAQ for more specific info regarding wiring and how the valves work.
