Chally wrote:Try checking the cable adjustment. Get someone to push the accelerator to the floor, & see if you can move it further by hand at the butterfly. If you can, then you have to take the freeplay out of the cable. I have even found pedals bent causing the same problem.
My Q was only getting about 90% when I bought it, & the extra 10% does help![]()
Chally wrote:
Why???, probably for performance reasons.
VimyJ wrote:Nope. My cables are tight. I noticed this situation while I was cleaning the throttle bodies. When holding the cable cam back as far as it goes, the butterflies don't open the full 45 degrees. This seems to be designed into the system. I take it from your experience that you think that these valves should open fully. There seems to be a designed throttle body constriction engineered into engine. I wonder what purpose this might serve and if altering the stops could give some performance gains?
If you can open the hood, then you can get to the TB's.There's two of them. One on the left and one on the right. The black plastic intake system is hooked up to them.mateo wrote:How hard is it to get to the throttle body on a 93 J30? I am someone mechanically inclined and I'm a DIYer. I need to clean them. However, I'm not even sure where to start. I have the owners manual but it doesn't reveal much.
Mateo
