Well I did some quick internet research and found that it is true, you can't buy the cap separately from the master cylinder for this vehicle from Nissan, so you will either have to find a cap at a junkyard (if you are lucky) or on eBay. From what I found it appears the only Nissan vehicles that use the same master cylinder in your vehicle are the 2013-2015 Altima and 2013-2015 Maxima. The part number for the master cylinder is: 460103TA0A
Of course, there probably are caps from other vehicles that would fit, but you would most likely need to test fit them, some junkyards might have a box full of different caps that you could try.
I checked eBay and found that nobody is currently selling only a used cap, but there are quite a few selling used master cylinders with the cap. The lowest price I found was around $60.00, still too much money when you just need the cap, but still much better than spending $250.
http://www.ebay.com/itm/16-NISSAN-MAXIM ... Og&vxp=mtr
