What was suggested to me from Kensun when I installed their HID kit was to run the headlight HID's on a wire harness to utilize the power better since our vehicles have Automatic head lights.ppan76 wrote:Crap. One of the Morimoto HID lights doesn't come on on the first try. I have to flick the switch once or twice before it works. I was expecting better quality from the Morimotos since they are double the price of the cheap ones.
Need to take it apart to troubleshoot.
:-). I didn't use the relay harness. But interesting that you mention the automatic headlights. That's what I had it on when I did my testing. I read the harness was not needed for our cars.CustomLowz wrote:What was suggested to me from Kensun when I installed their HID kit was to run the headlight HID's on a wire harness to utilize the power better since our vehicles have Automatic head lights.ppan76 wrote:Crap. One of the Morimoto HID lights doesn't come on on the first try. I have to flick the switch once or twice before it works. I was expecting better quality from the Morimotos since they are double the price of the cheap ones.
CustomLowz wrote:What I did for Relay harness in mine (for the fogs) was jacked the front up and put it on stands. Removed both front wheels and all of the plastic shields in the wheel wells. Then I found that a crossmember goes from one side to the other and is hollow on the inside. So I put the harness into another layer of wire loom, and fished it through. Now it is hidden from the elements, and fully functional.
Mine was the compplete opposite. It worked great for the first 2 weeks, then a fuse popped. I replaced the fog fuse and it popped again. I then set up the relay harness and had no more issues sinceAWGD8 wrote:CustomLowz wrote:What I did for Relay harness in mine (for the fogs) was jacked the front up and put it on stands. Removed both front wheels and all of the plastic shields in the wheel wells. Then I found that a crossmember goes from one side to the other and is hollow on the inside. So I put the harness into another layer of wire loom, and fished it through. Now it is hidden from the elements, and fully functional.
That is pretty neat! But I never had a problem with my HID foglight setup directly to the OEM wire harness. I had issue with the low beam HID , but got fixed by installing a relay harness.
Yeah, I found the reverse polarity too. Plus I had to modify the relay harness to make it longer and the connectors didn't work to the lights themselves, so I had to take them off. No biggie at all. Nice and tight waterproof connections. that's all that mattersAWGD8 wrote:I remember when my car was new, I let a shop worked on my HId foglights. The good thing was, the tech let me watched the installation. I remember he popped the fuse 2x and found out the foglights has reverse polarity? Something like that, and he flipped the polarity connection and sliced it to the foglight and then it worked!
That is how I learned HID stuff. So the next time I upgraded the HiD , I did it myself.
