LayNLow240 »
https://forums.nicoclub.com/laynlow240-u33346.html
Tue Aug 21, 2007 1:37 pm
1: It is in the head or oiling system somewhere.2: You don't need to replace the valve.3: Refer to #1. If it is a big piece, it could clog one of the oil galleries, or starve the engine for oil if it is big enough to clog the oil pickup. But if it is that big, the only way that it could have gotten out of the head is if it jumps up and over the cams and down the front of the cover. It is probably still in the head, and if that is the case then it wouldnt really damage anything since it cant float.You do not need to replace the valve. But you do need to replace the cam that has the chip in the lobe. To get the shim and bucket out of where it sits, you will need to remove the cam on the side your working on, grab a magnet and pull it out. It is angled in there, so dont try to take it out straight up or it could get a little stuck. If that happens just try to wiggle it back and forth, up and down until it moves freely in its hole. Putting them back in is the same way. make sure you angle it to match the angle of the hole, then let it slide in.
