Bushings
RedNissan333
Car: '94 Nissan 240SX LE
Anyone have a magic way I can stop doors from squeaking without replacing bushings in my '94 240SX? WD40 just isn't cutting it as they NEED replacing but I don't have the cash/know-how to do it :frown: Thanks in advance! :)
Reason: Moved to correct forum
NolimitZ32
try dry graphite or white lithium grease, ultimately you'll have to replace because if there is rusting on the contact surfaces its pretty much unrepairable, if you are able to disassemble and clean them up really well then grease and put back together you may be able to breathe some life back into them but I imagine you may need a press I've never done this before so I am just speculating.
RedNissan333
Thanks! Gonna try the graphite (cause I actually have some) and see...
