Postby
jms19delta »
https://forums.nicoclub.com/jms19delta-u136592.htmlWed Jun 24, 2009 12:34 pm
I have the energy suspension differential bushings and I am wondering if they need to be pressed in or is this something that I can do myself. I have seen different write ups...one said they needed to be pressed, and one said they didnt.
Postby
SirSilvia »
https://forums.nicoclub.com/sirsilvia-u39031.htmlWed Jun 24, 2009 4:12 pm
Mikes14240sx on zilvia wrote:The bushings aren't pressed in. There just sandwiched in when you remove those two front bolts the rubber bushings fall right out.
Postby
adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.htmlWed Jun 24, 2009 9:21 pm
they don't have to be pressed in.
They're actually easy to put in if you think you're savvy enough... lift you're rear end up by the diff, and you'll probably even see the gap it leaves between the 2 bolt washers and the actual diff (due to worn washers).
