Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Sat Oct 01, 2005 4:03 pm
naw alignment is only when you mess with things that change caster camber toe or ride height (ride hight changes all those for you)for the front, Unless your struts bolt holes are slotted for camber adjustment you can take it all apart, all the settings are made at the factory, and are non adjustable.
and yes for the most part its that easy... You dont have the D-bracket bushings too? If you got every thing just unbolt the nut and bolt holding the D-bracket to the car, and unbolt the endlink. Put silicone lubricant (should be supplied) on the inside of the bushings and then put them around the bar. For the endlinks you should have 2 new bushings each side. one goes on top and one on bottom, make sure you have the washers in place, then tighten the nut till the bushings start to plump....its that easy
