BUSHINGS...replacement bushings found!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
There are some bushing out there that are finally available for us
Check it out.
http://www.mynismo.com/products/?id=5348#
joe603
Car: 2014 Durango R/T
Sweet! I love a good bush...ing
tollboothwilley
lol
bushings are a worthy upgrade especially if you are swapping out any suspension parts
improved performance, improved wear
eZg001
Car: 06 G35 coupe 6mt
I'm curious if the bushings in aftermarket camber kits, coilovers, etc would be of the same quality as these?
They wouldn't need lubing, insert puerile comment, since they are rubber instead of polyurathane would they?
While I know a tad bit about the wonderful type of bush........obviously not much about automotive bushings. I have heard theories concerning the flex of the bushings in our suspension and the possibility that the flex may be adding to tire wear.
tollboothwilley
bushings can almost transform the feel of the suspension
if you have replaced the camber/toes then i'd recommend just the control arm bushings...
depending on your mileage, maybe some others as well
4drmadness
Car: 04 g35 infiniti sedan
what type of bushings are there, and which would you recommend changing. stupid loud clunking in the rear passenger side wont go away.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
That is a good find. The installation process for that is not going to be fun at all though. I have pressed a few bearings but as many of the suspension components are aluminum they have a tendency to mar and become distorted easily.
tollboothwilley
the pressing of these bushings turned out to be pretty easy...of course, I was using someone else who had the tools and knew how to press them!
haha
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
