frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Tue Feb 24, 2015 4:03 pm
On some Nissans the control arm has to be changed with the bushings. However, its been found that you can change them out independently if needed.
As for your sound, I wouldn't expect a worn control arm bushing to rattle unless it was really, really worn. Like down to the metal worn. You might want to start looking elsewhere.
If it were me, I'd get a somewhat mechanically inclined friend to pull on the suspension parts while I was in the car listening for the same noise. Things like the end links, sway bars, steering column, etc.
