Bushing replacement?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
kanenui808
Car: 2004 G35 sedan VQ35Det AT
Aloha,
I have a 04 g35 sedan AT i have a set of D2 rs. I have the upper front control arms, have the rear upper camber arms will be getting the lower camber arms along with the traction bars. Thinking i should replace the compression rod bushings as well as the control arm bushings for the front of the car, maybe the rear control arm bushings Has anyone else went all out when getting coilovers :confused:
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Compression rod bushings are a high fail issue on this car. Whiteline makes an essentials bushing kit specifically for it and we carry it on our website as well.
https://www.tunerzstore.com/Infiniti-G3 ... s-350z-g35
raremotive
Car: 04 Infiniti G35
Define all out?
I say the lower control arm bushing are the most common to go.. then the compression rod bushings.
The vehicle essential kit in the post above mine covers all the bases pretty well actually.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
