Burnouts in a G35
stanjaqnsen
Car: 2017 Q60 Red Sport
2017 QX30
I used to own a 2001 Ford SVT Cobra Mustange that did amazining burnouts. Since I got the G35 I have never been able to do a burnout with it. I know its childish but once in a while its just fun. The car should have enough power to do a brake stand yet I can't do it. I turn off the VDC . Is there just not enough power in a 5AT 2005 G35 or am I missing a step or two
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
there's plenty of power, its just that Nissan has had a little system that will soon be mandatory thanks to the DOT... its brake override. The ECM kills engine power when there is heavy throttle applied and brake force as well. Some people go around this by playing with the brake switch so they can hold the brakes and burnout...
joe603
Car: 2014 Durango R/T
You can do it...but you have to not use the brake...
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
yeah infiniti will never have a stuck accellerator problem... lol... toyota dosent have a brake overide feature...
but even my g35x could do a short burn out... but more of a drift cause you had to pull a curve very hard... cause holding the brake doesnt work...
stanjaqnsen
2017 QX30
So am I to understand there are no work arounds or temp changes one can do to bypass this system
Poyzinous
you can pop out the brake lamp switch and keep it closed
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Did somebody mention Mustang!?!? :nono: :poke:
stanjaqnsen
2017 QX30
I did. Had a 2001 SVT Cobra coup, laser red. bought it new and just nsold it in the spring. It only had 7000km on it, still new.Loved the power in that car
What do you have
audtatious
stanjaqnsen wrote:So am I to understand there are no work arounds or temp changes one can do to bypass this system
Titan owners hacked the harness and installed a switch to allow them a bypass when they needed it. Someone would have to try to break down the G wiring harness to see if it's possible on ours or not.
SVTCOBRA
stanjaqnsen wrote:I did. Had a 2001 SVT Cobra coup, laser red. bought it new and just nsold it in the spring. It only had 7000km on it, still new.Loved the power in that car
What do you have
First car was a 69 Mach 1 (351W / 3MT / shaker) - got me thru HS and college
98 GT convert / 97 Cobra / 96 Cobra convert - more recently
No mustangs at the moment, but that 5.0 is calling!!! :yesnod
audtatious
Buddy of mine had a '69 mach 1 with the 428CJ. It was the burgundy color with reflective yellowish stripes going down the side and the ram-air setup. Car was a monster!
cbak999g35
Car: 2007 G35
1995 Mustang Cobra
2007 VW Passat wagen - wife's car
I've got a 95 Cobra vert with hardtop from the factory...1 of 499 made.
