1dollar240 »
https://forums.nicoclub.com/1dollar240-u221.html
Thu Sep 19, 2002 5:54 pm
A more in depth description of a line lock: It is basically a valve that is installed somewhere in the line for the front brakes. You hold the brake pedal, flip the switch for the line lock, and let go of the pedal. THe line lock holds the pressure in the line on the front brakes, effectively locking them and leaving your rear brakes un engaged, allowing you to "spark" as many rims as you see fit. If i recall, they usually cost about 80 bucks to get put in (don't quote me on that) but its not a hard thing to install yourself, if you are at least a little mechanically inclined.
