ca18detgabby »
https://forums.nicoclub.com/ca18detgabby-u56657.html
Mon Mar 17, 2008 4:34 pm
you are running rich as in too much fuel?
that could be a number of things........ vac leaks, spark plugs, coil plugs, drop in resistor, FPR, issue with Tb, massive over cooling.......
much more.
what OTHER condition are you having? running rich when gas is at nearly 4 bucks(already that and more for some) is not a great thing.
If I had to guess it would be related to plugs or coil plugs....... but knowing what other issues you are having could also result in running rich.
