Burning Rubber Smell
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
Just what I could do without. It snowed in MA on Friday 3 inches and not the sort of weather to working on the Q. Tonight after getting in from a long day at work I noticed a burning rubber smell from the front left side of the car. It is too dark and cold to mess with it now but I am not sure where to start to look anyway.
Any suggestions. I will need to drive it to work in the morning in it and I probably stop after a few miles to check it out
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Check the belt condition, could be a seized idler pulley.
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
^^^^^ Great idea 911!
kimrober
Car: 1996 Q45t, 2002 Q45
Valve gasket.... I just replaced mine
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
kimrober wrote:Valve gasket.... I just replaced mine
Ditto on that one.
rover3l
Took it to the shop today and up on the ramp they could see that the smell was coming from fluid which had dripped on to the exhaust system. They couldn't detect where it was leaking from and have added a detector which apparently will show up under a UV light. I am going to take it back after 500 miles of driving. They thought it could be a main engine seal or possibly coming from the sump but couldn't be sure.
Does the main engine seal on a Q typically fail.They also said that maybe it is another fluid apart from engine oil but that will be looked for if the UV test does not show anything
DAEDALUS
Silly rabbits. 3rd vote for valve cover gasket. I assume "main engine seal" means front or rear shaft seal? Those aren't near or above the manifolds.Slap on a latex glove and wipe your hand around the perimeter of the valve cover on the side the leak's on.
squeefoo
1999 Infiniti I30
[QUOTE=rover3l]Tonight after getting in from a long day at work I noticed a burning rubber smell from the front left side of the car. [/QUOTE
A proper description gets you a proper guess.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Squee,
I agree with you wholeheartedly, oil shouldn't smell like rubber, but I know my ds vc is leaking & it smells like burning rubber to me, too.
Now mine has gotten to the point I have to change it AND the ds motor mount this weekend because the oil probably helped kill the mount.
squeefoo
1999 Infiniti I30
(Squeefoo scratches head) ds vc?
DioxylSulfate? Viet Cong?
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
"Took it to the shop today and up on the ramp they could see that the smell was coming from fluid which had dripped on to the exhaust system."
rover3l
Is that an active Q?
If so check you Active system for leaks I had one that smelled very very bad like plastic or rubber burning.
Just a thought if the UV test shows no results.
I know how to fix an F-18 Hornet (USAF) but the Q45a is even more complex!
Sorry no cool car pick i'm @ work
pito11213
Car: 2002 Chevrolet Suburban
Just by your description I must say valve cover gaskets. Mine needs RTV and the smoke comes right from where you described it. Facing the car left hand side towards the rear where the oil falls on the cat.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
squeefoo wrote:(Squeefoo scratches head) ds vc?
Driver's Side Valve Cover
rover3l
Sorry guys but it did smell like burning rubber, even the shop guy didn't think it was oil at first. However he checked everything out and found some type of fluid on the exhaust system at a position where he thought it must either becoming from a rear engine seal or sump gasket. I did not see where he was referring to as I left it in the shop all day while I went to work.
It does seem from all the replies that the valve cover is the favorite but the shop guys seem to think it is lower down. He did also say that because the smell was not a typical burning oil that it could be another fluid such as Power Steering fluid.
Yes the car is an active model and I didn't think of a leak from that system. I will check all fluid levels tomorrow when it is light
DAEDALUS
rover3l wrote:However he checked everything out and found some type of fluid on the exhaust system at a position where he thought it must either becoming from a rear engine seal or sump gasket.
Not sure how that's even possible. Has he figured out the engine is longitudinal? And that it's a V-8?
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
It flew out of the front main seal then the wind sprayed it on the manifold. =O j/k
Good point about them not knowing how the engine is sitting by the looks of the upper intake manifold.
GreenQ45a
I bought this "Greased Lighting" when my GreenQ45a go her valve cover seals, TB cleaning , fixed many Active leaks and noticed this stuff turned the color or the fluid it was cleaning trans fluid was red, Active fluid was yellow, and engine oil was purple or grey I don't quite remember (It was April).
I really liked the FORD April fools thing.... Bastard's
Anyway was it was like 3.75 a bottle and a GREAT cleaner and a great troubleshooter. just spray it on and see what color it turns
What have you got to loose?? 4 bucks??
Justa thought...
