Burning out spark plugs
Bfish
Car: 1993 Nissan 300zx twin turbo manual tran
Good morning guys had a quick question for the experts. Cylinder 5 and 3 burnt both plugs out melted off the tip and broke the porcelain. This is the second time this has happened same Cylinders. Wondering what might be causing this. I am getting an A/F ratio gauge installed next week to make sure I'm not running lean on top end as this seems to be happening only on highway pulls. What are other things to check for......as always thank you for the help!!!!!!
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
My guess would be detonation especially if you say melted tip and broken porcelain. Hope nothing was left in the cylinder.
I asked in your last post, “ did z1 give you a old style 555 tune or new style 555 tune?” They are slightly diff 555 vs 615.
May not be the main issue but can contribute to a leaner condition. What boost, fuel and plugs are you running?
Bfish
I spoke with them and they said it was for the old style 555s.....if its running lean I will have to get a custom tune
Bfish
I sinstalled new plugs and its running perfectly again but I dont want this scenario to keep recurring ....what would you.suggest I check beyond the A/F ratio
Bfish
What is the cause of destination..... lean conditions?
Bfish
I was running ngk spark plugs i got from Z1 i just got a new set of ngk plugs from specialty z that have a 8 heat rating
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
That is a colder plug should help. Lots of things can cause detonation, have you confirmed that your mechanical timing is at 15 deg with a timing light.
Bfish
That is getting done next week as well as the A/F gauge being installed
Definitely plan on that before doing any more unmonitored "highway pulls."
Always best to tune in a controlled environment (dyno).
Bfish
Yeah thays the next thing on the list as well I need to get a good tune but not many people will tune it up by me.....I'm currently running a z1 nistune but thays a very generic tune
