C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jan 30, 2004 10:21 pm
The exhaust valve stem seals are cheap(under $5.00 a piece). And you can do the work with the head on. Essenitally, you remove the valve cover, and exhaust cam. You should then be able to pull out the cam buckets. I'd do one at a time to make sure not to mix them up. You'll need a special valve spring compressor. It's about $70 or so. There are a few different ones, but I found one that hooks underneath the intake cam as a fulcrum and pushes down on the spring with an arm. I had to grind down the arm a bit as it wouldn't fit inside the bucket. But once you compress the spring, you remove the retainers. Then the spring. Then you can access the seal. I suppose there might be a special tool to do this, but I don't have it and a good set uf needle-nose with some careful handling did it for me.
And you will definitely want to do something to keep the valves from falling in. Compressed air through a compression or leak-down tester attachement is a good option. Even better is to actually remove both cams so all the valves are shut, so that you don't have to rotate the crank as you move from one cylinder to the next. But then you will need to make sure you have the appropriate sping compressor (one that bolts down to something on the engine as the fulcrum). Keep in mind, compressed air can move the piston making it want to turn the crank. You should make sure to set the parking brake and stick the car in 5th gear. You might as well chock the tires as well. And don't use too much air pressure. My Chiltons manual say to use 71 psi.
Another trick you can use to keep vlaves from falling is to use a soft, but think nylon rope. Feed it into the combustion chamber through the spark plug hole. Then move the cylinder to TDC. This should push the rope up agains the valves and hold it there. Make sure you leave the end out so you can pull the rope when you are done.
Install is reverse of revomval. But you'll want to use something to push the seal down around the base. A deep socket and hammer worked well for me.
