I wouldn't run a solvent such as Seafoam in the crankcase, it can potentially loosen large deposits that can clog oil passages or the oil pickup. Perhaps through a vacuum line is ok, though. 20% of the oil capacity substituted by Marvel Mystery Oil has been equated with a slow, gentle cleaning process by many members on Bob Is The Oil Guy, it may be worth trying for an oil change or two.
Perhaps your PCV valve is malfunctioning, but it's quite difficult to access and replace. Another possibility is a power valve screw falling out, being consumed by the engine, and causing engine damage which could be manifested in the form of oil consumption, but such an event happening on our VQ35DEs is a rarity. It's possible that the right hand valve cover has been clogged; read
here.
What brand of oil and oil filter are you running? What is your typical oil change interval?
