Burning Oil
sr kid 88
Car: 91' sr240
ok so i just had my motor freshly rebuilt top to bottom at a shop and it is burning oil. white smoke constant out of exhaust. they did a compression test 125 across the board and i believe oil was on 2 of the spark plugs. anybody know what this is and why? Thanks
Justin35ll
Car: s13 coupe sr20det
white smoke is usually coolant burning what does it smell like? Should be sweet125 compression is pretty low what internals did you put in during the rebuild?
sr kid 88
Car: 91' sr240
then it is bluish cause it is definitely oil.cp 8-5-1 pistons 87mmdarton sleeves eagle rodsbc stage 3 272 camstitek adjustable cam gears er rocker arm stoppersbc valve springs and retainersferrea 1mm over valves oem valve stem sealssupertech bronze valve guidesgreddy oil pangreddy intake manifoldtomie big bore throttle body
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Im having the same problem right now with after my head build. I think it might be the valve stem seals on mine but the guy said they were nice and tight and he said the guides were in good condition. But im stuck between 3 things. 1 headgasket but compression is high 140 ir higher across the board. 2 turbo seals are bad , i checked for shaft play and there was none and the turbo had less then 1000 miles on it. 3 bad valves or valve seals. If you figure it out please post it.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
What kind of turbo setup are you running? Cause you might need an oil restrictor if your running t3 or t3/t4. I had a similar issue and it would just pour smoke until I fixed it.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Some shops have difficulty resleeving. The result is leaking coolant.
125 across a fresh build that hasn't been broken in is good. My motor before it was even turned over and running on its own power made 120 on all 4.
sr kid 88
Car: 91' sr240
running bottom mount gt3071r. and the only thing it about my compression is i don'tt wanna get the car back and in a couple months be right back to square one you know
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I've also seen engines run so rich that they smoke white. What are your AFRs and what are you doing for engine management? If that isn't the issue, a leakdown test will tell you where the oil is coming from.
sr kid 88
Car: 91' sr240
hijacker after your motor was broken in what were your compression numbers like.
i had emange ultimate but then i took it off and i had a jim wolf already so i got it reprogrammed for my new setup. the shop owner is talking with jim wolf to get a new chip burned to fine tune the air fuels better. at idle they are about 11.5-12.2
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
What are you afrs driving? Your idle is really rich and there is the possibility that you can wash the rings out with the much fuel. Does your oil smell like gas?
sr kid 88
Car: 91' sr240
car is still at shop idk what air fuels is at driving jim wolf said when driving the air fuels go leaner and no it doesn't smell like gas
sr kid 88
Car: 91' sr240
found the problem. valve guides. thanks for all the help
