BlkrwdT »
https://forums.nicoclub.com/blkrwdt-u27852.html
Thu Aug 24, 2006 11:02 am
when I 1st purchase my '06 coupe at 300 mile I started to do the REAL break-in process, redline that sucker. As bad as it sound, now at 9K miles , I have put 4 1/2 quart in and at oil change 4 1/2 came out.
Of course the manual will state to drive under so and so rpm just to save thier ***. But really you need to really seal those rings properly and the only way to do it is high pressure/heat combustion.
Extra oil, more than what recommended, is not good. Your crankshaft will whip up a nice froth bubble whenever your oil is too full and contacts with the crankshaft. This will cause air in the oil in terms will destroy your bearings as air will not lub them very well.
