burning lots of oil
massmotors
Car: 89 240sx coupe
i have a 89 240 with the ka24e and it burns a whole bunch of oil like from full to empty in a 2 hr trip and i cant figure it out i did a compression test and its 170 across the board it runs fine i just have to keep putting oil into it but the coolant in the overflow tank turned brown recently and yes ive searched and found nothing any ideas what it could be?
neverlift
does the car smoke blue oil?
sounds like a cracked block honestly due to the oil/coolant mix.,..
massmotors
Car: 89 240sx coupe
it looks black but its hard to tell when i go wot the smoke like billows out
LayNLow240
Car: 92 240 coupe
i would say headgasket. cracked block is unlikely, but if the compression test turned out solid high #"s all the way across, then it might not be a headgasket. next thing to try is a leakdown test.
massmotors
Car: 89 240sx coupe
thanks ill try that next and yes it is blue smoke
240sxmech
Car: 90 240sx
valve stem seals are shot
massmotors
Car: 89 240sx coupe
if its the seal how would i get oil in the coolant?
chr1su12
try running thick oil for now to get you out of trouble.
massmotors
Car: 89 240sx coupe
im running 20w50 already
neverlift
lol yeah your in trouble then....that would explain such strong comp too.as for oil in coolant its a headgasket or bad block.... as stated most likely its the h/g.
