jetbuilder wrote:Brand new pistons(.30) and rings, block was bored .30 over. the shop measured the new pistons and bored the block accordingly. new bearings, full gasket kit including stem seals.
there is only 3 ways you could be burning oil that i can think of..
#1) head gasket........sometimes people forget to torque and then loosen again and re-torque there head gaskets..causing a falure..allso..you may be using the wrong style gasket for your aplication and not even know it..as there is no magic tuner book in the states like there is in japan with option mags..ect...we only get crappy articles that advertizing pushes on us...#2) pistons/rings....after a rebuild..you do need to go throu a break in period...but i never ever herd of such an oil loss with standard break in...one way this can happen thou is with the wrong size pistons or with rings that were gapped improperly..but even then..the gap would have to be large..#3) last but not least would be those pesky valve seals...these little bastages are a real pain...and if there leaking..you bet you would have fouwl'd up plugs ect....
now that we can narrow it down..its time to be sherlock and find the culprit!....#1. rule of tuning....never trust a build shop!..verify every thing your self...
********************recomendations*****************#1) head gasket...i dont know about others..but i only use full Copper head gaskets..they run $85.bucks ...and need some machine work for your head and block ( meatal O ring and reciever grooves) $200.bucks...so basicly 285.ish bucks for a head gasket that can withstand 7000hp...thats rite 7000hp..ps..requiers a spray on sealnt..hard to explain..but as you can see..next to impossible to blow...great for turbo cars.
#2)..i would recomend that you pull the valve cover off and cams..take (1) buckt and spring set out and verify the valve seals were changed..on each piston on each side..so (4) total...and if this is still not the culprit...the its off to check #3
#3) pull the head off of your block, remove the rod bolts and push the pistons out the top of the block from the bottom side...and meashure bore in (3) different places top/middle/bottom of each cilinder no less than 6 meashurments per cil....then meashure your piston's acording to the piston makers diagram..you will allso need to know ring gaps and the maximum allowd tolorance for piston slop...
this may all seam a hardcore task..but in reality..once you know how to do the above...you will laugh at all the times you had someone else do the work for you...hope this helps in some way..and i wish you luck sire.
