1st thing, RESPECT for the help!
They clam debris got on the MAF and caused it to burnout. As far as the symptoms, I'm not sure of the correct terms so ill just tell you what happen...
This past Friday I decided to feed a little speed to my rid, was going about 90mph on the highway. I came to a light – stopped, and turned to head down the street near my apartment. Once I turned, I felt the wheel of the car tighten up. I pulled to the side of the road to figure out what was going on. I turned the car off and when I tried to turn it back on – the lights on the dash were flickering and the rpm needle was going up and down. The car seemed to be revving and then would just stall. I unplugged the battery and re-connected, same issue. Then I towed it to the dealer, the rest is in the original post up top.
So if I install it myself, the car's computer will relearn? no reprogramming of the system needed?
