burn time and misfiring
iHEARTmyCS14
Car: 1997 nissan 240sx
my burn time are around 5-6 millisecond and i was reserching and it said it should only b 1-2 milisecond what should i do. also my engine r mising when i drive (once in a while but mostly when i am takinf off) any suggestion?!
-g0ku
5upra
Car: S197
haha...how did you figure out your burn time and not be able to figure out a misfire
iHEARTmyCS14
hummm i use the skools's machine 2 c the burn time ......
-g0ku
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
burn time should not matter as far as a misfire is concerned. if the problem is only at initial accel and idle check for vacuum leaks. is you ignition timing set correctly? are you using ngk plugs? are the injectors leaking down?
iHEARTmyCS14
hummm im not sure about my plugs but they are prety new, msd ignition system nology wire everything is on right triple check everything already
-g0ku
driftingmy240sx
check for vacuum leaks and ignition timing. i have seen 6al boxes mess up also.
iHEARTmyCS14
wats 6al?! but ok ill chekc my timing!
thx!
-sUNNY d.=
driftingmy240sx
msd 6al box (6al is the system designation) its the type of red box that msd gave you and depending on the system it gets a different label.
