for almost 2 weeks now my car has been burning insane amounts of oil, in the mornings or after it sits for more than 2-3hrs at start up it burns and smokes for about 5mins. when accelerating it smokes and i can feel hesitation cause of the wet spark plug and its only one plug so im thinking its a piston ring others are saying it could be the head gasket. it leaked for the first 2 days then stopped, when it was leaking i thought about the rear main seal. so ive checked with some mechanics and all have given me estimates on fixing either piston ring or head gasket with prices from 1200-3800$. since its my only car i cant leave it with them just for them to check it out cause i need to go to work & take kids to skool, with out this car we're up creek. but in a week im able to take off work and kids will be with my in-laws so that will be the only time to fix this, anyway . ..
so im stuck on either buying a full rebuild kit (pistons/rings/gaskets/springs/bolts/timing)700$ + labor is about 800$
OR already have price on a new engine 1900$ 2yr warranty unlimited mileage
or even if its worth it a VQ35 swap 1900$ (same warranty) plus if any of you know what will i need to do for that swap to happen PLEASE im all ears ... motor mounts? trans? ecu? ive got about $3K to spend
if you have different ideas on what it could be please drop me a line before i start putting money into it. thanx
so only one spark plug is wet with oil on threads and abit burnt & i clean everytime after use. so far it has burns 4.5quarts in alil less then 2 weeks, i put oil in but not as much as needed cause it smokes so damn much but oil on dip stick is at about half or abit less.
