mmm240 wrote:It's a little bit, but all over. Have any of you used this POR 15?
What I'm really asking is how to take care of it. I could go nuts with my angle grinder, but there are many places I wouldn't be able to hit with it.
the angle ginder w/ the wire wheel is obviously for larger areas that are easy to access, the smaller the spot the smaller your tool of choice will have to be.
por-15 is great stuff and can be used over metal thats simply been scraped clean of loose rust, so dont worry about getting the tight spots spotless, just get as much off them as possible and then coat them
i just like getting as much rust off as much area as possible before i start to coat the metal, because obviously the cleaner the metal the less chance of a "recurrence"
