buncha BS shifter ^&%*@
canadian booster
Car: 1993 Nissan Z32 TT JDM
so i manage to fumble my way through and get the shifter out in order to put in the shortshifter i ordered from some guy on 3zc .. uhh.. wait a sec, shouldn't it be shorter than the stock one? and there's a piece missing from the bottom ring,.. and the retainer ring around the balljoint is busted, wtf..
ok, well that's a piss off, what a waste of time and money, so i put it all back together again, and .. oh nice.. it's upsidefkingdown..
*grrrr* tore it all apart again and fixed it and put it back again..
silver lining: while it was apart i fixed the doubledin dvd player and the oem digital clock .. still a piss off though
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
At least ou found something productive ;)
canadian booster
Yea it was pretty sweet watching starwars and driving around today haha
mrmoose
Car: 91 300zxtt
Thats a short throw... it just has a longer lower arm or whatever to reduce throw distance...
http://www.twmperformance.com/short-shifter.html
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Did you compare the distances between the pivot ball and bushing?
300ZXttZMAN
itsa300zx wrote:Did you compare the distances between the pivot ball and bushing?
This.
canadian booster
i cant' compare anything, there's a piece missing from the bottom, the one i took out has a cylinder that a bolt goes through, the new one is just a big open hole..
either way there's a piece busted that i'm pretty sure is important, maybe there's a trick to getting that retainer ring onto the plastic that surrounds the balljoint, cuz i cant' figure it out
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
The brass colored sleeve should just pry out in two halves. I believe it is just a place for the bolt to mash against rather than sinking into the rubber. But the broken part is a def downer
