Well my buddy ended up joining the military 2 weeks ago and deploys to boot camp in a week he just sold his car and today he was cleaning out the garage and found a whole bunch of stuff he has for sale. Some brand new in box never opened some used heres a list of everything he has. I have seen all these items and have them in hand so i can vouch for them. Well heres the list
Apexi Twin Chamber Blow Off Valve BRAND NEW IN BOX-
TWIN CHAMBER BLOW OFF VALVE
High-flow blow off valve
Compatible with a wide range of applications, from stock to high boost setups. Attractive finish.
A good blow off valve is an absolute necessity for high performance turbo systems. A well-engineered blow off valve prevents turbine damage by quickly relieving excess boost pressure without sacrificing boost response. Conventional blow off valve designs require choosing between flow capacity and boost response - blow off valves with high flow capacity generally have poor boost response, while blow off valves with good boost response are not able to handle high flow capacity. A'PEX engineers have developed a solution to this dilemma by creating the Twin Chamber Blow Off Valve.
The Twin Chamber Blow Off Valve is an adjustable, high-response unit for use on a wide range of applications. Rather than relying on the vacuum chamber alone, the Twin Chamber Blow Off Valve harnesses boost pressure in a second chamber to assist in opening the relief valve. This design allows the use of a unique flat-valve design, which provides excellent valve response under both low and high boost conditions without sacrificing flow capacity. Valve reaction is adjusted by tightening or loosening the spring tensioning screw on top of the unit. Blow off sound can be adjusted by turning the red collar at the base of the unit. With its innovative design and adjustment features, the Twin Chamber Blow Off Valve is flexible enough for use on street cars as well as racecars. He paid 225$ for it hes looking to get 180$ SHIPPED comes with all hardware necessary for install.
second item- Oil Catch Can wraped in Carbon Fiber believe its greddy. BRAND NEW IN BOX come with all Hardware necessary.The oil catch tank mounts above your valve cover and ensures excess oil and dirt does not get inside your engine. This will ensure better mileage and better performance on your engine. Made of Billet 6061 Aluminum then TIG Welded with Billet Aluminum CNC machined fittings and then polished to high quality polish. The Filler Cap is CNC machined to fit perfectly and then hard anodized for color coordination and durability to last for years to come. Each Kit also comes with an Polished Aluminum Bracket and Stainless Steel Clamps, to mount your New Reserve Tank. Also Included is 3 Foot of High Silicon Clear Fiber Reinforced Tubing to route your coolant or Oil Vapors.he paid 85$ for it selling for 45$ SHIPPED
Third item-USED Turbo Works Inter cooler just a few bend fins used for 1500 miles still works flawlessly. Works awesome and good for up to 30psi. He paid 175$ for this willing to let it go for 100$ SHIPPED. Once again this is just the inter cooler nothing else. similar in size to the APS intercooler.
And last item- Fuel Pressure Regulator by Megan BRAND NEW in box never used red in color.Megan Racing knows that the fuel system is perhaps the most important system on any performance vehicle. If you don¡¦t have the fuel system to support the power the engine displaces, then your cars performance will suffer or worse take detrimental damage.
For this reason, Megan Racing offers our Adjustable Fuel Pressure Regulator. Made of polished aluminum, this lightweight regulator is universal and offers a 0-100psi-adjustment range to tailor to all your fuel system requirements. A fuel pressure gauge is attached to further assist in fine-tuning. (Note: Professional installation is highly recommended.)
he paid 80$ willing to let it go for 50$ SHIPPED.
Well that its folks if he finds any more stuff il make sure to post it. pics will be up shortly if intrested email me at
[email protected]
All prices are negotiable.
Modified by PsYchOG35 at 8:35 PM 6/21/2007
