Bunch Of Questions
dplesu
any help is apreciated
93 240sx got the 8.5:1 pistons 72lb injectors jwt ecu 255 walboro for the fuel pressure regulator what do i use? can i use the stock one
will the 72lb msd inj just slide in the intake with no modification they dont really seem to fit maybe i wasnt pusning hard enough
fuel lines the stock ones ok?(i am on a buget)
the engine is out now i started rebuilding it i got the full gasket set and timing chain kitany problems you guys ran into and wouldnt want someone else to face would be apreciated i am pretty mechanical inclined but u never know
stock rods, t3/t4 what recomandations for how high should i take the boost
ignition the msd 6a with the msd blaster ss (i have notices thet evrey one is using the blaster coil)is the blaster ss ok? p# 8207
just wanted to say that i have been reading this forum for a while now even before i had my 240. Without even knowing, u guys are influencing people all over the place i am almost done the project now and i have to say i could not have done it without you people thanks alot
Nathan
With those injectors, you have to use a top feed fuel rail, do you have one? This would certainly explain your issues with getting them to "slide in". Also, when you switch to a top feed rail, you can get one made for an aftermarket fpr (expensive usually, the fuel lines are a *****) or made for a stock fpr. Your stock fuel lines are ok, and should be pretty easy to make work if you use a fuel rail made for a stock fpr. Also, your stock rods should be ok for whatever you can manage with a T3/T04e, however...keep the revs at close to factory limits, thats what really seems to kill KA rods.
andrave
Car: 1989 Nissan 240SX Coupe
yep keep the revs low, your ignition should be more than adequate, JWT tunes for stock fuel pressure so the factory one with a top feed rail either custom or JGYcustoms.com style (top feed but uses factory fpr) would work, or you could always just get a 1:1 aftermarket. I myself with with a mustang rail which more or less fits and was 9 bucks, plus it allowed me to get a 30 dollar accel bolt on FPR for tuning, but it sounds like you have the money and the drive to "do stuff right" so I say go for the JGY.The stock fuel lines should be ok, they are of a decent size. You might want to replace the rubber lines on either end though, thats just a good general practice since they get brittle and tend to crack or split. replacing them with stainless eliminates the weak spot but is also a pain in the ***. upgrade your fuel filter for sure though, the factory one is small and a 300zx twin turbo unit will handle the additional flow and is commonly available. If you switch to braided lines just order a thread on unit from summit.while you have the engine apart you might want to remove the butterflies, they can be a restriction on high boost engines and its just one less vaccuum line to run.. of course if you have a later s14 its my understanding they do not have the butterflies so that wouldn't be necessary.with the kind of engine you are building up you might want to get some head studs too, and I'd guess you already have arp rod bolts for build up like that, but if not I would suggest looking into them.I'm still finishing up my motor, its waiting on hot tanking, honing, new rings/oil pump/bearings, new rod bolts, factory head bolts, and valvesprings....it'd be done but I'm taking a couple weeks for a vacation in florida to eat up all my money and time.lol 4 years in school and I'm finally done, I deserve a break.good luck with your project, what manifold are you using?
huguetpj
Car: 93 KAT Coupe
andrave wrote:while you have the engine apart you might want to remove the butterflies, they can be a restriction on high boost engines and its just one less vaccuum line to run.. of course if you have a later s14 its my understanding they do not have the butterflies so that wouldn't be necessary.
Actually they were removed somtime in 93... I know cause my car ain't got them.
dplesu
i do have a top fed fuel rail but it is not drilled yet
about the mustang fuel rail how close is the fittment
andrave
click the drunk and go to page 2 there is a pic there
dplesu
andrave wrote: what manifold are you using?
just a log manifold homemade
