C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Jul 07, 2003 8:08 am
To eliminate the bumpsteer, you have to key in on why the toe is changing during suspension travel then remedy that. It is possible the things you mention could eliminate it, but unless it remedies the cause, it won't fix it. The best way to check is to remove the spring, and install the shock with no spring. With the car in the air, you move the suspension up and down with a jack, 3 inches of bump and 3 inches of rebound from normal ride height. Check the toe changes at each 1 inch interval. Try to figure out what is causing the toe to change excessively.
