Q45tech wrote:My [with 30 foot of wire] outdoor peak hold digital thermometer always tells the tale. That the worse situation is the 50>100F underhood rise when you shut the engine off. The underplenum can go from 200F to 300F for 10-15 minutes without hood vents or electric shut down fans.
I think he means to install a digital thermometer and measure the temperature under the worse conditions (Stuck in traffic at 100*F).
Compare what idling at 650 RPM's VS 900 RPM's does in terms of temperature.
I don't think it will make a big difference but thats my hypothesis.
Q45tech wrote:Obviously this exceeds the knock sensor rated temperature.
What is important is the running and shutdown temperature of the heads not the coolant [except for conduction back to transmission].
I think this means that you shouldn't worry about idling in 100*F temperatures as much as you should worry shutting off the car after such temperatures.
If thats the case then do what 1 million mile man does (did?) with his Chevy ( ) and let the car idle for at least five minutes then shut the car off when going home. Or you could leave the hood open when you reach your house.
