Bumper Tutorial
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
BigBodyV
Car: Nissan Versa S
Yall should do a how to take bumper off tutorial an also how to install the intake.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
The cold air intakes can be installed without removing the bumper. All you gotta do is jack up the driver front end, remove the wheel, and you can connect the rest of the intake by pulling back the wheel well liner.
NODES
Car: 2007 Nissan Versa SL (Blue)
Need to remove the bumper to change the light bulbs
McLeod1981
Car: Brilliant Silver 2009 Versa 1.8S w/ power-package, cruise control
NODES wrote:Need to remove the bumper to change the light bulbs
No you don't you can access all the bulbs in the front headlamp assembly from the engine bay.
bumper removal only facilitates replacement of headlamp assemblies.
Shad0wXCalibur
^^What he said. To remove the entire headlight? Yes. But the bulbs? It's easy to change those out without removing anything.
NODES
Shad0wXCalibur wrote:^^What he said. To remove the entire headlight? Yes. But the bulbs? It's easy to change those out without removing anything.
tell that to my hands who had a whale of a time trying to replace the bulbs.
Return to “Versa Technical Discussions”
