Bumper brackets
turner
Car: nissan pickup 1993 v6 4x4 VG30E
Hey there, trying to make sure if bumper brackets are the same for front and rear. I am guessing so as only fronts seem to be sold on carparts.com.
Adverse Effects
Car: 1987 Nissan Navara 2WD 2.4L Z24
Base Standard Cab Pickup 2-Door styleside
5 speed manual
for what
a gocart
a bike
a trike
a kitchen sink
your little sister?
then you have what model and even what year
its amazing isnt it that there is more than 1 car/truck
whomadewho
Car: 1997 Nissan pickup
The front and rear brackets are different. On the front bumper the interchange is showing 1993-1994 - 1995-1997 not sure if the brackets will interchange? The interchange is showing the rear bumper - 1986 - 1997 will fit. The only difference I can see in the bracket is the OEM bracket has more holes than the Westin brand rear bumper but it looks like they will interchange. The Genuine OEM part number for the 1993 front bumper - H5011S3828. The part number for the rear bumper bracket is - UN1165107 95300. The 95300 - is the manufacturer part number. You can use either or both numbers. If you plan on buying the brackets, the best thing to do is go with a bracket kit which will include the bolts. Chances are good you're going to need the gas wrench to remove the old bracket bolts. If you're replacing bumpers, it's possible 2 wheel & 4x4 are different more so the front bumper.
