Fired right up but I have the middle cylinder on the drivers side bank not firing.
Eliminated the coil pack and plug, and the injector ohms out ok.
Need to check compression.
Is there a fairly easy way to verify the plug is getting fire ?
Its either that or the injector is clogged. But I didn't get a CEL at all.
FYI with all new pullys and tension roller it sure is a lot quieter !
