Great vid. From what I can tell from it:razah9 wrote:http://www.youtube.com/watch?v=109JwkoOAJM
Well I love it. From top down, A/F, Throttle, Intake temp, Coolant temp.+1 Timing, Premium Tune. Think 70ish outside.
Nice!! So it looks like mine is in that "sweet spot". I'd like to see what everyone else is getting (that's why I started this thread) so we can have a better idea of what exactly Bullydog did.Dexion wrote:12.2-12.5 is optimal range for a stable A/F ratio. Normal is usually low 11's or high 10's.Technosquare said that pre-reflash a stock ECU reported 10.8 for its A/F ratio. Looks like this thing is the real deal!
Whoa! 26!! I don't know how lean our engines can take, but that seems really, really lean. But, you're getting around 14.2 at WOT?BrianAdams03 wrote:I've been getting on average 14.2 A/F so far. There is a way to modify the ratio btw but can't remember exactly what it was called in the setup. It comes on setting A and you can put it on B but I wouldn't recommend it. I had mine on B for 1/2 tank of gas and got 3+mpg worse and my A/F ratio was around 22!! on average. And saw it peak at 26 once.
2008 3.5 CVT+2 timing, Premium Tune14.2(I do have ingen intake too btw)
Great find! Anyone else able to chime in and let us know if option B would be safe or not?grv575 wrote:So, special functions -> wideband sensor setting (A or B) chooses which A/F ratio you want.
It seems A uses ideal A/F (safer for say turboed cars, and maybe for non-turboed, not too sure. maybe an expert can chime in) of 12.5 average A/F.
B seems to use the stoichiometric A/F ratio of 14.7. Supposedly, this is the optimal A/F ratio (theoretically enough oxygen to burn all the fuel).
B is definitely faster, but not sure if I would run it 24/7 (fear of melting pistons & engine knock).
I wouldnt run b at all. Especially if it burns that stoich blend. i read on wiki that it produces alot of heat and isnt always the best plan.nurseryboy wrote:Great find! Anyone else able to chime in and let us know if option B would be safe or not?
grv575 wrote:B is definitely faster, but not sure if I would run it 24/7 (fear of melting pistons & engine knock).
No, sorry, at WOT it's at 10.5 and I've seen it get to 10.1.nurseryboy wrote:Whoa! 26!! I don't know how lean our engines can take, but that seems really, really lean. But, you're getting around 14.2 at WOT?
this is really what I was concerned about 10.5 is rich. Optimal tune for performance is 12.5 @ WOT. Guess its different for everyoneBrianAdams03 wrote:
Sorry guys can someone exlpain all of this A/f stuff Im assuming that it is increasing the amout of air into and gas intake??? But Im not sure...migs7585 wrote:So this is a stupid question but idk s*** about this stuff. What does this thing actually do
