Bully Dog (on Fuga)
Rob-bb
Car: Nissan Fuga 450
Hi, Does any one have any experience with the 'Bully dog Triple Dog GT Platinum Gas Tuner 40417' ? And if so is it likely to have any problems on the Nissan Fuga 450 variant of this car?
I assume the electronics are identical, but as I am in New Zealand it's likely I wont be able to return the item if it doesn't work, assuming it doesn't brick the car that is :chuckle:
Ilya
Welcome to the forum.
There was someone around here who said that Bully Dog was fine but the rest of us, unless I'm out of the loop, use/used UpRev.
Rob-bb
I looked at uprev website but it's sort of broken which I thought was a bad sign, when I try to search by automobile that dropdowns don't work.
Rob-bb
Un update, I have had a reply via email from a uprev reseller here in NZ and they say the uprevs do not work on the Nissan Fuga, there are some differences in the ECU and the parameters used, and also the data logging apparently.
