Bryson »
https://forums.nicoclub.com/bryson-u1889.html
Wed Apr 30, 2003 8:37 pm
ehh..I as far as I know none of those things has to do with bullet proofing an engine. BUllet proofing an engine from my understanding means making it able to withstand high boost and resist the effects of detonation through the use offorged pistonsforged rodsforged cranksleeved aluminum block or int he case of RB... nothing since its an exremely well built iron block.usually a metal or partial metal headgasket designed to withstand the pressure of high boost.
I'm sure titanium valves and other head work may be considered bullet proofing...
but to answer your question...
to bullet proof RB 25...forged pistons /w probaby lower compression *.5 instead of 9)forged rodsI'm pretty sure the crank is really strong.. if not I think the RB26DETT crank is forged and would also raise your liters to like 2.6 or 2.7
The transmission should hold more power than you'll be making I'm sure.The clutch is the same as an N/A 300ZX(z32). ACT. SPEC. OSGIKEN. EXEDY. all of these should have some sort of clutch to match your power....also Daunttless, Night7racing, Unstable-Hybrids, and Mickinney motorsports should all sell the things your looking for..
I personally plan to purchase my RB through Night due to where he is...his prices... and his communication.
