tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Thu Sep 22, 2005 12:19 pm
this is my plan.... but it just occured to me, this might be overkill, because the CA already has a built-in oil cooler...
for high boost application 18+ psi
remote dual oil filter system (one normal for down to 20 micron, then another filter for 1 to 20 micron) with a temp switch for an air/fluid oil cooler, then a 1.5 quart oil accumulator .. to allow a lower level of oil in the pan = increased power from less drag on the crank?
is this overkill? ... planning on getting into auto-x with this car ...
and then if i use this setup, i should be able to cut the oil cooler out of the engine coolant loop, to help keep engine temp down (using a stock radiator, and except when the system was dry, i never saw the temp get above half on the meter, actually just below half.. it goes there and stays there.
