Bull Bar Installation question
Car: 2001 Nissan Pathfinder LE
Does anyone know if u need to completely remove the tow hooks to install the brackets. For some reason i'm having a hard time adjusting it so it sits to the proper height..Instruction says remove the two 10mm bolts but my passenger side tow hooks has 4 bolts and my driver side tow hook has 3 ........probably easier with help as well :(
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
IIRC, I only had to remove two of the bolts to remove my bull bar, so no, you shouldn't have to remove the tow hooks. However, it may help to loosen the third and fourth bolts. And yes, surely it's easier with a helper. Try putting up one side on a stack of bricks or a jack.
Hey RGK did u get my PM...not sure if i properly sent it thanks
