BULBS
QDog26
Car: 1992 Pearl White Q45
Can anyone tell me what type or #bulbs to use in 1992Q door window switch and instrument panel warning lights? Also how do you change the bulbs in the center console window switches? Thanx.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
For the power window switches in center console and on each door:
Every other bulb:
1992 INFINITI Q45
Low beam headlamp9006 9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen9006EB EcoBright - Your Environmental Choice9006XV XtraVision Halogen - The Brighter Light9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp9005 9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen9005EB EcoBright - Your Environmental Choice9005XV XtraVision Halogen - The Brighter Light9005CB Cool Blue Halogen - The Whiter Light
Parking light1157A 1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal1157A 1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal1156 1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light1157 1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light1157 1157LL Long Life Upgrade: Up to twice the life of the standard lamp
High mount stop light921 921ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style921LL Long Life Upgrade: Up to twice the life of the standard lamp
License plate168 168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light1156 1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker168 168LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Dome light194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area158
Instrument-general194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Check engine indicator194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Hi-beam indicator194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Seat belt indicator194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Brake warning194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Automatic transmission indicator194 194LL Long Life Upgrade: Up to twice the life of the standard lamp
Directional signal indicator194 194LL Long Life Upgrade: Up to twice the life of the standard lamp\
Source: http://www.sylvania.com/Consum...s.htm
And it would be easier to order new switches than to change the bulbs in the center console unless you have small fingers and are good at solding.
But I am sure someone less lazy may tell you how.
goody90q45
Car: 1992 Infiniti Q45 (sold)
QDog26 wrote:.......Also how do you change the bulbs in the center console window switches?
On the 94-96 Q it's very simple since the bulb and socket can be seen on the bottom of the switch. A 5 minute job.
On the 90-93 Q you'll need to disassemble the switch from the backside (4-6 tabs?) and install the Radio Shack bulbs shown in the pic. Bulbs for these switches are not available from the stealership. Take your time taking the switch apart and putting it back together since a few things have to line up properly to make it all work again.
QDog26
Where can i order the switches?
Infinitiguy19
Infiniti Of Scottsdale, AZ: http://www.infinitipartsusa.co...id=55
svairman
the 194 for the instrument cluster is wrong, only 5 of the bulbs are 194 (i have the cluster out looking at it) there are 2 other sizes. 7 of a slightly smaller bulb and 2 very small bulbs on either side of the diag message screen thing. Does any body have a replacement number/ fix for these? I called the local nissan dealer and they want 30 a pop for them. That's $270 in lights :nono: I don't think so
